Knock Sensor Low Voltage DTC?
PT's Slowest Truck
There's a TSB in reference to knock sensor issues...water gets under the intake and into the valley cover and corrodes the knock sensors and possibly the sub-harness to them. GM wants you to replace the knock sensors if corroded, and I *think* possibly the sub-harness if the terminals in the connector are all green. After the new parts are installed, you have to build a "dam" with RTV around the knock sensors to stop water from getting into them. I've seen pics around here somewhere, where somebody has done the repair with the RTV...may be in the GM section.
Pull the intake off and they are right there on the valley cover. There are rubber gromets were the wires go down to the knock sensors, just rtv around those before you put them back in and that will seal them better then the rtv damn the tsb recommends (just makes them alittle harder to get back out). Then pull the back foam piece off the intake so any water that gets in there can run out down the back of the motor (also recommended by the tsb). Not to bad of a job, take a few hours if you're not rushing. I would also recommend replaceing the intake gaskets while you are in there.
Well pictures are worth a thousand words so here are some random pics I have of Knock Sensor replacement and sealing. Enjoy!
Picture of Knock Sensors deep in the valley cover:
You have to squeeze the clip on the opposite "wide" end of the clip to release it from the knock sensor stem:
Another look from the side:
Once you swap the sensors use some RTV to keep the moisture out. I personally did not get too crazy with it, just made sure it sealed the boot:
Here is another picture of someone on this site and how they approached the "Dam O' Silicone" to keep the water out:
lucas287
31
01-12-2021 06:18 AM
Pontiac Derek
09-19-2015 01:49 PM
creekrat
09-10-2015 12:59 AM
