l83 and 6l80E swap problems
i have been fighting with this swap for a while now. 97 Silverado and I am putting a 2018 l83 and 6l80e. I can't find anyone having the issue I am having. I have had some gremlins and my harness builder helped me find one problem, but now I have a new problem.. The first problem the harness builder help me solve was the motor would just rev up on its on or as soon as I tapped the pedal it would just rev up. Ended up being a bad pedal. Now my new problem is when I shift to reverse it reves up and if I switch back to park or neutral it idles back down. The trans never feels like it engages forward or reverse but I don't give it long because it reves up too quick. I attached a file of the scan and you can see the prndl channel change and then the rpms shoot up. I have check grounds because I know they can cause all sorts of problems but they are good. I have several DTC;s but they are permanent and my programmer says they aren't really a problem. Any iideas would be greatly appreciated.
Not enough information in that file to do much other than confirm there's a problem. You have a lot of duplicate variables recorded but you're missing a lot of critical stuff, namely all of your estimated, desired and actual torques.
Ok Thank you for responding, can you tell me what all I need to monitor please, maybe a snapshot of what you monitor? I am new to this, but I am trying desperately to get this build done its been a nightmare.
Thank you for the scan. i included the channels and ran another scan, would you take a look and see what you think please. I see it thinks its in 1st on the current gear channel but the prndl status shows park, kinda of confusing
DTC's are
P0097 Intake Air Temperature Sensor 2 Circuit low (Permanent)
P00F4 Humidity Sensor Circuit Low (Permanent)
P0113 Intake Air Temperature Sensor 1 Circuit High (Permanent)
P0691 Fan 1 Control Circuit Low (Permanent)
P182E (Permanent)
P1915 Internal Mode Switch Does not indicate Park/Neutral (P/N)During Start (Permanent)
P182E (Permanent)
Yeah you're gonna have to look into resolving those before making it much further with anything else. Sounds like the PRNDL might have a floating input. Or maybe switched out with the pedal position wires, based on that data
