LC-1 Install Help
Originally Posted by Blown02Sierra
thanks for all the help! So do i need to ground the system and analog grounds to the chassis as well as plug them into the EFILive blackbox logging box?
Whippled496, is the actual box to the wideband inside your console, or is that hanging underneath?
And when you say u punched a hole, you actually drilled through the floorboard? Where is the closest grommet?
Is it possible to have the lc-1 box inside of the cab w/o extending the o2 wires?
Do you all suggest permanent install or temp?
Those w/o an xd1, do you use the normally open switch and led included in the package for your open air cal?
I tried plugging the serial cable into my pc and could not get a reading. Does the lc-1 need any sort of power to be programmed?
When installed, are the plugs(forgot what they're called) plugged or open? (ie, do i put a terminator plug in them?)
wow, thanks for all the help.
One more ?. have any of you used the usb to serial adapter thingy? Is it just a direct wire or does it use a converter in between? Any pics?
Well, i tried to find a direct cable at radio shack and the all knowing radio shack employee tried to get all high and mighty w/ me saying that it wont work and theres no such thing and they are two different technologies, so i told him that i know that they are two different technologies, but im using a wideband controller w/ a (radio thingy? forgot what its called) plug and it already has that **** built in and says so in the manual but he kept cutting me off saying yeah, sure, right. Fu(k radio shack. Im going to fry's.
Destroyer of Transmissions
The one that didnt work came from Radio Shack. They are not too bright up there.
http://cgi.ebay.com/BELKIN-USB-to-SE...QQcmdZViewItem
NEW SLOGAN:
"Radio Shack..you've got questions, we have blank stares"
LCHEE
10-24-2020 04:10 PM
zblee
08-03-2015 03:45 AM
FlowmasterMufflers
07-17-2015 03:26 PM
