Locked TCC Torque Table
I noticed this table has numbers less than 640 in it. Is it part of my lackluster performance? (Table Data)
And I noticed this table has my TCC locking in performance mode. (Table Data TCC)
If I raise the tq. table to 640 across the board, will it destroy the clutch? (I'm running 7psi boost)
And lastly, in HP Tuners Transmission Auto TCC Apply/Release-Apply/Release speed it lists Normal,Cruise,Hot, and Performance tables.
Does the PCM decide which table to use depending on how you drive, or must one of these tables be selected and applied by the tuner?
Thanks, Mike.
Thanks, Mike.
As for which table it chooses goes like this;
Normal - everyday driving
Hot - When the trans temp reaches a certain temp degree
Cruise - when using cruise control
Performance - Tow/Haul button pressed
Cammed4ever
09-30-2015 03:38 PM
