logging truck and need info
Old 03-07-2009 | 01:36 AM
Dark Halo's Avatar
Default logging truck and need info
I just got EFIlive v2 and the place I bought it from is going to tune my truck off the log I send them. My question is what PID's I need to use and how many runs do I need to make (full throtle, half, ect) Thanks for any help
Old 03-07-2009 | 01:53 AM
kbracing96's Avatar
You should ask them what they want to see, if they're tuning it based off what you send them.
Old 03-07-2009 | 10:27 PM
Dark Halo's Avatar
I know I should ask them, But they are closed until monday, and I was just trying to send it to him asap
Old 03-07-2009 | 10:28 PM
BlackGMC's Avatar
Resident Retard
If you don't mind me asking where are you getting it tuned?
Old 03-07-2009 | 10:30 PM
Dark Halo's Avatar
a guy by the name of Jeff who use to do thunder racing's tunning. He is also who I bought my efi live from
Old 03-07-2009 | 10:43 PM
00ChevyScott's Avatar
Wearin' da big hat
I'd try to keep the PID's to a minimum to help keep the log smooth. If you try and log too much stuff all at once, it can't keep up and will make a sloppy log. Also, EFIlive has the ability to filter the logs, so I would just do a mix of different stuff on a couple logs
Old 03-07-2009 | 10:45 PM
viciousknid's Avatar
Where's the Beef?
isn't the point of having it to do your own tuning?
Old 03-07-2009 | 11:55 PM
andrew383's Avatar
traveling mod
i log with-rpm,speed,maf,map,ect,iat,kr,timing,tps,injB1/B2,o2B1/B2,ltft B1/B2,stft B1/B2.
i think that should be a good start if its the first time using it.
get your truck up to normal temps and do a few WOT runs( through 1st and 2nd)and some part throttle with a mix of driving.take a 10-15 min log of driving around and you should be good to go.
but double check with your tuner to see if he wants more.
to some yes,im learning on my silvy but the ss ill leave in the hands of real tuner.
Old 03-08-2009 | 12:03 AM
Where's the Beef?
Makes sense.
Those look like good pids to start with.
Old 03-08-2009 | 12:17 PM
Dark Halo's Avatar
very ture but this is to get me started, I have lots of reading to do before I just jump into it. I have already recaled my speedo and removed the speed limiter, I just want the new 06 to run better now and not later.
Bumpers
08-04-2024 10:44 PM
wrb002
08-31-2015 01:00 PM
GMCtrk
07-17-2015 07:39 PM
00pooterSS
07-16-2015 04:03 PM
black6spdz
07-16-2015 02:32 AM
