looking for a stock tune
i have HP tuner and looking for a stock tune for a 06 chevy 1500, the one i have now is not right . can someone point me i the right direction
thanks
thanks
You will need to log into the home page. Under the top set of tabs,(forum/press release) there is a link for the repository.
Since you are new at this, you may not be aware you cannot simply grab a file and load it. The tunes are VIN specific.
You need to find one that is similar, or what you need. Then copy and paste the values in the appropriate cells. Those values can still be "off" as every engine is different. I'd suggest you go to HPT and read,read,read, then slowly start with some basics in making changes.
What exactly is not 'right'? Do you have a tune or running stock?
i have a 5.3 stock , i am trying to loose the high idle on start up , i was able to get a stock tune and play with it a little , but still have the high idle , i also have flex fuel injectors ( not running flex fuel )
thanks
thanks
