lpe gt1 cam installed now won't idle
#21
You need to match the base sprak tables close to the main tables. That will give you a smoother transition from one to the other.
About the fuel trims ... if you are getting -12 at idle, I would start with subtracting 10 from it in those cells, JUST the idle cells.
#22
Originally Posted by 4.8T
the pressure modifier for each shift is 0'ed out?.
the lower the number the less pressure the higher the number the more pressure, 0 is not a null value each tranny will be different
These are also the tables I use for modifying the 1-2 with a shift kit leave the base table stock and manipulate shift pressures with these tables. dont raise the force motor current table if anything it can go down. Aftermarket stall raise the tcc locking table. I think thats about all I use to adjust line pressure and shifting habits, dont have HPT in front of me.
ARC
57
02-21-2022 10:54 AM
Mossyoakglock
07-17-2015 08:30 AM
all_individual
07-13-2015 11:01 AM
