LTFT at 0
Wrong. The closer they are to 0, the less the pcm has to add or subtract fuel to achieve a 14.7 to 1 air fuel ratio. Most pcm's will add or subtract up to 25% fuel before a rich or lean code is set. If you see -7 it means the pcm is reducing fuel by 7% but it can still control the air/fuel mixture.
blownerator
Originally Posted by quicksilverado
Correct me if I'm wrong. If the computer is not jumping all over with the LTFT and is staying close to stoic then the fuel mileage will be bettter.
Just something to think about......
Has anyone ever looked / scanned a 2006 truck? How close to zero are the LTFT's in a new vehicle? GM calibrates these vehicles for fuel mileage, in this day and age fuel mileage is mandated by the government and demanded by the public. There is a margin for error +/- in the pcm to allow the computer to adjust for unforeseen issues down the road. What you tune to zero today might be +/- 10% in a week with climate changes, dirty air filter, potential vacuum leak, bad tank of gas, altitude, barometric pressure, driving habits, etc, etc, etc.
IF the LTFT's are at + 20% (lean) the vehicle is still running stoichiometric, if the vehicle is running -20% (rich) the vehicle is still running stoichiometric. Zero % is still Stoichiometric, the only difference is the computer does not need to do anything to correct for a rich/lean condition.
there is time better spent watching paint dry than try to nail down 0% on your LTFT's.
Well, I beg to differ on the LTFT not needing to be at zero and leaving them alone. If the vehicle is running +20 at part throttle, the ECM is working very hard to keep the O2s around 450mV (it couldn't careless about AFR). This will cause it to add fuel when you go WOT, about 20%. So if you were running 12.5 without the fuel trim correction at WOT, it would be 10.5 with the fuel trim correction. The computer will always add fuel (+ trims), but will not remove fuel (- trims), this is a safety feature. If your fuel trims are off by more then 10% either way, I would highly recommend you get it tuned, especially if you have no other mods planned. The ECM from the factory is not calibrated properly, it is only calibrated to pass certain mandated regulations, and even then most OEM calibrators do not follow a set manufacturers' protocol to accomplish those results in a similar fasion. Now if the ECM is maxed out or not calibrated properly, other conditions are also affected, like torque calculation which is used for torque management and shift pressures for autos. By calibrating the ECM to run around 5% fuel trims, you are assured that your vehicle is running at it best. Granted, running 16.7 is best for fuel economy, and this can be reached safetly with a proper tune. Just my thoughts on the subject.
blownerator
so you are saying tune around a possible mechanical issue?
+/- 10% is acceptable, otherwise the PCM would set a code for being rich/lean. Do you know what the threshold is to set a SES light? Again, the PCM is always looking for 14.68:1 when cruising, the +/- readings only mean it is working to get there. I guess if you want to give that hard working PCM a break then yes, tune to 0%.
There are MILLIONS of GM vehicles running on the road today without any issues....then only time these cars have "problems" is when the user gets a scanner and does not understand the strategies used to calibrate a vehicle.
Originally Posted by BlownChevy
so you are saying tune around a possible mechanical issue?.
Let me step back and add this, since we are in the tuning forum and I suspect everyone has decent knowledge of mechanical workings, only after all mechanical issues have been resolved. When you are assured no mechanical issues, then proceed. But we are digressing here.
I am not looking to argue over tuning methods, surely you have your own and I have mine. This is the tuning forum where people want to learn about tuning so they do not screw up their vehicles. They want to understand how things work. I will gladly help those interested in learning any way I can. Take care!
