LTFT very high in bank 2
I plugged the EGR plate with a bolt, cut the head off then welded it to ensure it never leaked. About a week after the install, I went back and tightened the collector bolts again. I might weld the studs in as well. I am wondering if the bung is not letting the o2 down far enough into the exhaust stream?
After I swapped the o2's and ran it for a bit in SD, it ran better. I couldnt figure out how to tune fast enough so I hired Mr. Wheatley to tune it with my HP Tuner. Money well spent for me.
i did check the connectors on the injectors.......... they looked plugged in.... but I'm not 100 percent if its working everything was running fine .... even had an exhaust leaK from broken manifold bolts and the truck ran better
Did you reuse factory manifold gaskets or the supplied? I reused the factory gaskets on mine. You might have cracked the sparkplug or didnt get the wire pushed on all the way. I know the #5 and #7 spark plugs were a pita to get in, #7 had to be installed from underneath. #6 should be relatively easy to get to.
I used the stock manifold gaskets.... always they are awesome!!! I'm going to go pull the spark plugs now.... and have a look at them on bank 2... everything on bank 1 is working fine
I put new wires on
I put new spark plugs in.. Delco replacements
If you get a universal swivel and a long extension you can get the #7 and #5 in from under the hump from the top of the truck with no problem
I put new wires on
