making an autotrak T case work in another vehicle
Old 11-27-2011, 04:02 AM
rumblebox's Avatar
thanks man. that's a lot of info. i have the OS from my old 99 silverado. i'll probably use that.
Old 11-27-2011, 04:05 AM
Custm2500's Rude Friend
1FastBrick's Avatar
was it 4x4???
Old 11-27-2011, 04:06 AM
rumblebox's Avatar
yep. 5.3 4x4
Old 11-27-2011, 04:08 AM
1FastBrick's Avatar
Ok then. Should be good thats exactly what i have...
Old 11-27-2011, 04:13 AM
1FastBrick's Avatar
I won't be able to scan anything till monday when I get to work.
Old 11-27-2011, 04:14 AM
rumblebox's Avatar
i'm just researching now anyway. it'll be a while before i go through with the swap.
Old 11-27-2011, 04:22 AM
1FastBrick's Avatar
LOL. Not sure what your goals are might be easier to just get a TBSS...
The bigest thing is how to make the Jeep stuff work with the GM stuff electrically
Old 11-27-2011, 04:24 AM
rumblebox's Avatar
i'm basically running the GM PCM as a standalone, piggy-backing off the daimler computer since it has to be there for the CAN BUS to work properly.
Old 11-27-2011, 04:26 AM
1FastBrick's Avatar
Ya I am just not sure how to get the proper signals to things like the Cluster. Sound like you have it handled though. Do you have the auto trac case or a trans??? How about a wireing harness???
Old 11-27-2011, 04:27 AM
rumblebox's Avatar
i'm building a cluster. i'll probably wait until i need it to get the Tcase and harness. i still need to trade my 2wd 60 for a 4wd unit also.
i'm still figuring out how i'll make the A/C work though. i'll probably build a bracket and use the chrysler compressor. i may have to run a manual switch to the compressor clutch since the PCM wont be receiving any engine signals.
Quick Reply: making an autotrak T case work in another vehicle
