Max timing issue. I'm at a loss.
Old 11-17-2007, 03:12 PM
TurboGibbs's Avatar
See, you can teach and dumbass something. Thanks.
Old 11-18-2007, 05:14 PM
Zick's Avatar
Originally Posted by TurboGibbs
well, the forum doesn't like the config file. not compatible i don't guess.
You can just rename the file extension to something like *.doc and upload it. Then whoever downloads its to look at it will have to rename it back to the correct ending extension.
Old 11-30-2007, 03:25 PM
TurboGibbs's Avatar
Sorry to bring this up again but I have one more question.
Is there any way to accurately log timing and use the info in the editor? Is there any way to make your hi/lo oct tables reference rpm vs kpa instead of rpm vs g/cyl?
Old 11-30-2007, 05:53 PM
03sierraslt's Avatar
Hmm, I dont think but I really cant answer that... Maybe foff will chime in..
Old 11-30-2007, 10:47 PM
LS1TECH Sponsor
foff667's Avatar
Theres 1000 different ways to do what you want using histograms, it really depends WHAT YOU WANT. The #1 & #2 default histograms are good starting points, using filters & such are another.
No, the stock pcm maps it again g/cyl not against the map sensor.
Old 12-01-2007, 04:01 PM
TurboGibbs's Avatar
Ok, enough with beating around the bush, This is WHAT I WANT. Can you show/tell me 1 way that I can log timing and be able to use that information accurately, directly or indirectly, in the hi or lo oct. table in editor while in Speed Density?
Old 12-02-2007, 02:59 PM
TurboGibbs's Avatar
Every time I change the x axis in the histogram away from g/cyl all it will show is one cell in the upper left hand corner.
Correction, I can change x to kpa and the table does well. But that does me little good.
Oobray
06-13-2022 03:38 AM
97aztecgt
08-13-2015 02:11 PM
05GMC4.8
08-07-2015 09:55 PM
GMCtrk
07-17-2015 06:39 PM
ferrellrooster
07-13-2015 09:53 AM
Quick Reply: Max timing issue. I'm at a loss.
