My codes: p0420 and p0430
Now, you can get a non-CARB compliant y-pipe with cats for $656, but it's not nearly as pretty or as well flowing as the stock Y-pipe.
Since Pierce County, Washington does smog tests, you will need to start with replacing the rear oxygen sensors, then if the code continues replace the y-pipe. The OEM y-pipe is $1710.79 plus labor. Tuning the codes out of the computer is not possible as you will likely fail the smog test.
Midnightrider
05-15-2014 12:42 AM
Midnightrider
05-09-2014 08:03 AM
