Need to add more fuel in EFI Live.
Question for you guys. Just got my tune back from W4M. I need to add some more fuel. What tables in EFI Live need to be adjusted. I'm told that im running lean. Jesse told me that he tuned my truck for the Stock 6.0 injectors. However I'm using the 4.8L injectors. So im sure i need to add some more fuel. I'm new to EFI Live so im not sure what to change.
Are they stock 99 injectors, or later model one's? In 99 all the injectors where 21.8lbs/hr. 2000+ are all 25.2 lbs/hr injectors.
Table B4001 should have 21.8 in all the cells if they are the stock injectors for your truck, from the stock tunes i looked at.
I'm showing in that table 3.1 all the way down... but my table variables are Injector Flow Rate (Grams/Second), and Manifold Vacuum KPa.
Am i supposed to change all those to 21.8?
Allright, just tried that, and im still gettin KR all over the place. If i go anything over 25% throttle, it jumps right to 8.0KR and starts retarding timing. Here is my tune file if anyone can take a look at it for me.
