Need to add more fuel in EFI Live.
Here is a log file. I did a little reving while it was in park. There was no knock. but you should be able to see whatever it is you need to look at. I did a WOT run through most of 1st gear. Let me know what you think. Thanks a lot man.
He didn't seem to be to helpfull. He wasn't sure of the problem, he just kept saying that he tuned everything for my exact setup... which it looks like he did. Its just that I have some sort of KR issue... I think my knock sensors are bad... If im not running lean, then its gotta be a false reading.. Is there any other way to determine if im getting false knock or not?
Not that i've really heard..... I think the only thing im hearing is when its trying to retard timing when im beatin on it. I dont really hear any pinging or anything like that... Could valvetrain cause knock?
Valve train noise will usually give you random anytime KR, not just when your getting on it. You could 0 out tables B6204 and B6205. That would basically disable KR, but your playing with fire if it does knock, as it wouldn't pull any timing. The only protection from knock you would have is your ears and you foot.
Allright man, well thanks for all the help and all your input, i appericiate it. I'll let ya know when i get it running good, i dont know if i wanna disable the knock sensors or not.... Hopefully some more people will put in some input and maybe have some other ideas. Thanks
Lyle
Lyle
