Need Check Engine Light Help!!!!!! Mass Air Flow Sensor?!?!?!
Well now I have a new MAF but when I was trying to clean it I was just using that MAF cleaner from the auto parts store. I've heard you can use carb cleaner but I've also heard that is too harsh on the sensors.
Sounds good, I appreciate it. It might be awhile though cause I'm working up in the sticks of Minnesota so it might be some time but I'll keep it in mind.
10 Second Club
well i logged the truck yesterday LTFT and STFT were outta control +25 LTFT and +20to +50 STFT....reset them to see what the truck would do didnt even wanna idle or run until they went way positive again..
o2's would flat line one in a while lean..and just sit there..so there is a lean condition.
told him to buy 2 front o2's and we will go from there gonna log it tommmrow and look at the LTFT and check for vacuum leaks at the manifold and around.
might be a good thing jas to throw a FF on it to while we are at just for ***** and grins if u havent changed it lately..
Good to read you got her all fixed. Good way to diag this in the furture would be to log STFT and spray some carb clean brake clean etc around intake and all over until STFT go -.. there is your leak. Most engines will through lean codes around +15
tweeder
09-18-2015 11:02 PM
bsgiffor
07-19-2015 11:14 AM
Suburban2500
07-14-2015 02:10 AM
