Need EXPERIENCED opinion on Fuel Issue.
Hey guys, so I have a 2001 Sierra ( see sig) Engine is as follows...
2003 6.0L LQ4
Comp 222/224 cam (LS6 Springs)
Ported/Polshed/milled .015 Heads
Shorty headers
8.1 injectors
I'm have a issue after the truck was Professionally tuned, with it running rough, stalls/sputters when hot, a/c on kills engine. My tuner is thinking its an issue with fuel vaporization in the rail, possibly because I'm running the 4.8 return style intake as opposed to the LQ4 returnless style? Anyone experienced this? or something similar? Is this a tuning issue or a hardware issue. Its driving me nuts, because otherwise the truck runs so strong.
Any insight?
Thanks.
2003 6.0L LQ4
Shorty headers
8.1 injectors
Any insight?
Thanks.
I understand, you just used the intake and fuel rails from your 4.8L. My truck being an '01 1/2 ton and coming with a 6.0L, I can assure you they used the same set-up. The only thing different with mine was it came with ETC instead of a cable operated throttle-body. The 3/4 ton and up earlier model trucks used the same set-up as well, albeit with a cable throttle-body.
The injector rail for a 99-02 4.8/5.3/6.0 IS different than a 03+ injector rail. If you look at the link I attach, the 8th picture down shows a 03 LQ4 injector rail with only one Fuel outlet (returnless style) the 99-02 have 2 fuel lines (return style)
https://www.performancetrucks.net/fo...-stuff-467773/
