Need a hand on HP Tuners.............
Well, lap top went south, sent in for repair. I'm docked up on the desktop- I've done alot of reading about stand alone logging and to make this possible you need to load your config. OK, how do I do that? I have the origina read and the lates file that I tweaked. Where do I go from here..............
Thanks
Thanks
kinda unsure what you are asking, but you need a laptop to log a scan, unless you have a REALLY LONG CORD, hahaha. Once you have read your pcm, you can tweak it however you want, then you have to reflash the pcm with your changes. But you definitely need a laptop to do anything.
Thanks
Thanks
In VCM Scanner: Connect the MPVI to your computer and open the configuration you want to log with (*.cfg) and CLOSE any open log files (*.hpl). Go to the Scan menu, then down to 'MPVI Pro Data Logging'. Click 'Write Config'. Comfirm erasing any saved logs on MPVI. Connect MPVI to car and use Record and Stop buttons (press for 2 seconds). When you are done, connect to your computer again, and go to scan menu and then 'MPVI Pro Data Logging'. Click on 'Read Logs'. VCM Scanner will read the logs and prompt you to save them just as if you logged with the laptop. After you save all the logs, you can erase them. I usually do it right away. After this, you can open the logs as normal.
Of course, this is for MPVI Pro only.
