need help or advice changing 80e shift settings
Old 03-08-2012, 12:34 AM
I have a gauge for that
Atomic's Avatar
You need to take into account your converter slip as well. I use that fbody calculator and then factor in torque converter slip as to what the true trans rpm is.
Old 03-11-2012, 03:14 PM
SmokinHot98's Avatar
smokinhot = noob w/HPT
http://f-body.org/gears/ and do what? The trans slip is the one this I haven't changed. So far it runs 110% better but it hangs up at the shifts so I'm playing w/the shift speeds more
setting at the time were:
Labels Speed
1 -> 2 Shift 41
2 -> 3 Shift 72
3 -> 4 Shift 109
2 -> 1 Shift 37
3 -> 2 Shift 69
4 -> 3 Shift 106
Labels RPM
1 -> 2 Shift 5600
2 -> 3 Shift 5600
3 -> 4 Shift 5600
TCC Set Max Slip RPM 5000rpm
TCC Set Min Slip RPM 1250rpm
TCC Clear Max Slip RPM 550rpm
TCC Clear Min Slip RPM 100rpm
File Type: hpl
File Type: hpt
Old 03-11-2012, 07:36 PM
Atomic's Avatar
keep lowering it until you get it to shift correctly. also, it looks like you started spinning, probably why it had trouble shifting. you are out of injector too
Old 03-11-2012, 08:23 PM
I got it to shift in all gears now, maybe drop it just a little lower though. I don't think it spun, I had clear dry ground during that log lol. Yea injectors will be put in when I drop in my brother's old tr220.
The truck is waaay different then before. The shifts are firmer, but my downshifts are there! I would lay into at 65-70 and it would drop to third, now it pulls hard in 2nd
Old 03-11-2012, 11:15 PM
I it got down fairly well
Now I'll just need a tune to dial in for the slick
File Type: hpl
1979rs/z28
09-23-2015 08:39 AM
1slwgto
08-16-2015 06:40 PM
fastjweb
08-15-2015 10:47 AM
lxcoupe
07-14-2015 10:14 PM
ferrellrooster
07-13-2015 09:53 AM
Quick Reply: need help or advice changing 80e shift settings
