need help with shift points
I changed my gears from 3.42 to a 4.10 with 295/50/16-27.7 tall tires. My rpms on 1/2 is 6350 and 2/3 is 6300 and 3/4 is 5800 in tow haul. In normal it is 6000 in 1/2 and 2/3 and 5800 at 3/4. I used a speed calculater that blackgmc posted on here but it still don't shift right. I adjusted the rpm and shift speed. Am I missing something. Its still shifting crazy. Im using hptuners.
9 Second Club
The looser the verter, the lower the mph will haveto be. Set the rpm where you want it. Then drop the wot mph by 1-2 mph at a time. Also make sure the part throttle table at 100% throttle match. Make sure wot and part throtle downshift tables are lower than the upshift.
jtphelps289
09-29-2015 12:00 PM
TAPyvehc93
09-14-2015 01:22 PM
