Need some help with tuning. EFILive
Is there any other way to do this without a dyno? There isnt one close. So just zero out the whole table then for now? Anything else that draws your thoughts off hand.
Looks like we are not receiving notifications with respect to subscribed threads.
Thanks DC Justin. Sometimes I forget that everyone with boost and tuning software is not running a 2 bar custom OS.
GM.AFR(commanded air fuel ratio) should be in the PID list. Did you Validate the PIDs with the FlashScan connected to your vehicle? (INFO> Validate PIDs)
The IFR table does need to be correct. I have seen these injectors setup anywhere from 5.0 - 5.3 g/s. Lower will get you more fuel.
Stay out of boost until the knock issue gets sorted out. Can you hear the knock? Is this a fresh blower install?
Edit: Boy you guys were busy while I was typing!
Just got back for a little drive and a log. As you can see i cant wait to get this KR issue taken care of. Im still seeing KR. The log is a cruise and a short wot run. Like DR.x said no more wot run till this is taken care of.
THe maf is stock unmodified. I have a Aem wideband on its way. It looked to me if im reading it right that I was still getting kr at a low rpm. what is causing that? Spark still? What do i have to adjust when i get my wideband? Im learning alot hear as we are talking.
