No Convertor Lock-up
I dont know what to do to fix my convertor to lock up... Trans temp gets up to 228+. when driving 70mph the rpm's are at 3000. check engine light is on but i dont know what the code is at this point... before when i checked the code it was a mis balance with cylinders??? I was told it was the TCC apply valve in the pump in the tranny... Everything is new and im just about to ... Need some help guys its making me
A stall, underdrive pulley, and/or a cam can cause the pcm/ecm to "think" it is misfiring. THe misfire tables either need to de sensatized or turned off to prevent this from prohibiting converter lockup. This may or may not be your issue, but Id see if that fault that is stored is a po300, if so, thats your culprit.
With out the code it's tough to say, but as mentioned if you have a miss fire code this will prevent the converter from locking.
Get the code read and let us know what it is.
Excessive trans temps is going to kill your trans life.
And to answer what you posted in the other thread
A flashing check engine light is a Severe Warning that you have a misfire. If you don't fix it, you can cause major damage. As mentioned I would recommend getting it looked at right away.
Yeah that was yesterday morning it was like 30' outside but i cut it off. waited an hr or so and it was fine just a steady light. but I cant tell any diff in driving and when i drove in to town it was fine 70mph rpm 2000...
Ok this am there wasnt a flash for check engine. trans temp was 115.. TC locked up through all gears an moved!!! again 70mph and rpm's was right at 1900!!! seems like it does only when trans temp warms up so im thinking its the TCC valve in the pump...
It was a plug problem.. rpm's all over th place no power..I took the E3's out and put in the NGK's! running fine now light went away... art for my TCC valve will be in today!!
