No heat at idle
Old 01-11-2012 | 11:44 AM
Yuke60's Avatar
Default No heat at idle
I'm really hoping someone can throw a few ideas my way on this one.
The truck is a GMC Yukon XL 2500 with 6.0L engine. When idling it will not blow heat out of the front or rear. Even if I let the engine warm up to normal operating temps, it just blows cold.
When driving, it will eventually start to blow warm air, but takes quite a while (10 min of driving). This morning, when it started blowing out warm air, it was also blowing considerably warmer in the front, and cooler in the rear.
If I let it idle, it starts blowing cold again.
Water pump? or are there other things that could cause this?
Also, the engine is essentially stock.
Old 01-11-2012 | 12:53 PM
slow67's Avatar
Gingervitis Addict
Check the coolant level. If its just a little low, it may be letting an air pocket in the heater core.
Old 01-11-2012 | 01:00 PM
Kemble's Avatar
Yes the coolant level doesn't have to be very low for no heat. Check water pump and pump gaskets if coolant is missing.
Old 01-11-2012 | 02:09 PM
Fastcount03's Avatar
Also check to see if your functions are cycling properly at the control head. Mine has done this several times, and I have corrected it by unplugging the control head for a minute and resetting it.
Old 01-11-2012 | 02:11 PM
Yuke60's Avatar
good ideas i will check when I get home. thanks!
bearden86
26
11-15-2015 04:58 PM
turbo6c3
10-05-2015 07:11 PM
BlownHD
10-03-2015 01:24 PM
02AWDAWSDenali
10-01-2015 06:08 PM
old motorhead
09-29-2015 09:22 PM
Quick Reply: No heat at idle
