O2 sims
O2 sims
My trans cooler, transgo and sims arrived today. The O2 sims say that they are for 98-02 C5 and F-body. Will these work on the truck, I did tell them it was for a 03 truck. Also when I opened the transgo box, I thought I ordered the regular transgo kit, but it has 4L60e HD2 on the box. So is that the Transgo HD kit Thanks for the help
My simms from my 96 work on a frieds 02, so they may work fine. I think the kit everyone gets is the HD2 for the Transgo. If its not what you want then send it back, but its probably what you wanted.
Tin Foil Hat Wearin' Fool
You got lucky with the hd2 its the good one I have it in my truck and evryone else pretty much has. And yes I believe the sims are the same for all the ls engines not sure but I would bet money on it. Check and see how they plug up if they dont plug in right then obviously they arent the right ones but when I was thinking of going that way I believe the speed shop said somethin about them being the same as the fbods.
Thanks for the info. I called TSP today and they said the sims should work fine. On the Transgo I guess I lucked out I didn't know about the HD2 till after I placed my order. And holy **** that is a lot of little parts in that shift kit lol.
Yup thats why they charge an arm and a leg to install it.
Nice looking truck. The O2 simms I had were from a 96 OBS witht he 350, they worked on my buddies 02 work ruck, and are now residing on another buddies 02 with a 6.0 and LT's. He said the ses went off the night he put them on and has stayed off.
I'll be with you on the shift kit. I just cant see spending the $$$ for installation for it. Guess I'll do my converter at the same time, and be wishing I paid someone Good luck post how it goes.
Hey thanks for the compliment white1. Talked to TSP today and they took care of the problem and said they would have the new ones on the way. Seem like pretty good people over there.
