obdII which fuse???
obdII which fuse???
my ses light popped on and im trying to check it but the obdII port seems to not have any power.but the cig lighter works, and i dont have my manual for my truck, its at home and im at work trying to fix it at work. all we have here that will read my truck is a old NGS. anyone tell me where the fuse is located? i know that its not in the box on the drivers side of the dash.
Check both the cig lighter fuse and the accessory fuse as well. My buddy's '99 just had the same exact problem this week. Got a check engine light and tried to scan it and no go.
No power to the cig lighter but the fuse was good. Found it was the accessory fuse that was blown.
I belive you want to check pin #16 for power. Maybe someone else will chime in and say if I am right. If I am right then pin 16 needs power inorder for the scan tool to comunicate.
Moderately Differentiated
alright well pin 16 has power , and i tried the same NGS on my buddys 00' silvy and it had the same problem, so i think its the NGs and not my truck. .. but i also have another question......if your trucks check engine light comes on, it goes into a "limp" mode correct? in which the pcm uses set parameters to go by and only uses the sensors it has to....or does it just ues a set parameter on the sesnor that goes bad???
dantheman1540
02-24-2016 09:56 PM
slowlsx
08-13-2015 08:28 PM
slowlsx
08-10-2015 05:33 PM
