Ok Guys Got Hpt
#172
haha that would be bad ***.. imagine tuning the truck from a phone... then again reading the histograms could be a bitch
#173
The log looks ok to me. With the AFR spark multiplier in effect you are getting ~28* of timing at WOT without KR for the most part... There only appears to be a couple of small spikes at the end of a couple runs and if you aren't hearing anything I wouldn't worry about it. The PCM will easily than compensate for that (if it is indeed real KR). The larger spikes at part throttle I suspect are due to some transient fuel changes or could just be false if you aren't hearing anything I wouldn't be worried about those right now either. I suspect when you get your VE in better shape a lot of that stuff will dissapear.
#174
lxcoupe
07-21-2015 03:12 AM
