OS update without removing/overwriting tune ??
Old 06-28-2006, 09:43 AM
12secSS's Avatar
Did you swap over your setting to the "new" OS file? I have done many OS updates and have not had a single problem like this, no crank relearn, no eliminating VATS.
Old 06-28-2006, 10:23 AM
rgvsierra's Avatar
Originally Posted by Yelo
It doesn't work.....I used Flash-->Write Entire and it wouldn't start, so I did the VATS relink procedure and it still wouldn't start....I wrote my stock .bin back in using the same procedure and it started right up. What am I missing ???
happened to me once, i dont know why but i just kept messing with the key, on off, on off, vats relink after each on off and it started up after about 3?? times of trying.
Old 06-28-2006, 10:26 AM
Yelo's Avatar
1slowsilverado: I'll try that....I HAD thought ofdoing that but wasn't sure what it'd do
12secSS: other than the different OS's everything is identical between the two.
I assume I have to use the VIN off the '00 .bin right ??
Old 06-28-2006, 05:25 PM
1slowsilverado's Avatar
You can do a manual relearn with the key trick on/off ten min's 3 times and it will start.
But for some reason if you Do a rewrite of an 02 over an 01 pcm it wont start buy just doing a relink with hpt, dont work?? So either just turn it off under system or do the relearn manualy with the key...
SLOPONY
20
10-18-2016 06:05 AM
mzoomora
01-03-2016 07:06 AM
wrb002
08-31-2015 12:00 PM
AUTOT3K
08-16-2015 06:21 PM
Ls3silverado
07-31-2015 04:22 PM
Quick Reply: OS update without removing/overwriting tune ??
