P 0300 code
P 0300 code
The run down... I just put an lq4 block with a turbo, comp cam xr265, #60 injectors in my truck. Its throwing a code p 0300 multiple misfire. I changed out the plugs, coil packs and spark plugs. The plugs are tr6 4177 gapped to 29. I did have it tuned on the previous 5.3 and turbo and was told that the tune would very close. Is it possible the tune?
Po300 is the pain in the *** code. Check to see if your intake has a leak.check make sure all 8 injectors are clicking. Fuel pressure test. Compression test...clean tb and maf also, that's all i can think of right now
Man I hope it has nothing to do with compression that sounds to serious. I've cleaned the TB and the Maf im got to do a little research on how to do the other test.
It very well could be the cam - it is common to need misfire tables tuned because they throw P0300 during low rpm with a cam. If it doesn't have any misfire codes coming in for specific cylinders, and it runs well with no apparent miss, that would be my guess...
