P0171, P0174 = ?
P0171, P0174 = ?
i pulled these codes from my truck a few minutes ago.
P0171
P0174
what do they mean?
any way to fix them?
i have not changed or modded anything on my truck recently.
i just read the sticky and it says they mean
P0171 - Fuel Trim System Lean (Bank 1)
P0174 - Fuel Trim too Lean (Bank 2)
what is causing this?
any and all help is appreciated
P0171
P0174
what do they mean?
Baltimore Whore
That means that the engine is running lean. Could be caused by a bad fuel pump, dirty injectors, vacuum leak, or pcv or egr valve.
John
John
Another thing to change is the fuel filter.
Put some fuel injector cleaner in there, change the fuel filter out, erase the codes and if you still have the same problem....you need to check the fuel pump voltage and psi on teh fuel rails....make sure it ain't going out on ya.
Blown06
06-22-2009 03:10 AM
fastjweb
11-01-2006 12:44 PM
