P0172 & P0179 codes, Why?
#21
Originally Posted by dc_justin
P0179 is your problem. Your fuel composition sensor is screwed up on the high side, presumably causing the PCM to think that you're running an 80+% ethanol blend. Since stoich for Ethanol is around 9:1, the PCM is targeting an AFR closer to that than 14.7. That's why you're running rich.
I'm going to delete the codes and see if they come back.
See quote below:
Originally Posted by DrX
Maybe disable the Fuel Composition DTCs, copy/paste B3647 to B3649 and set B3660 to 0 across the board if you won't be running E85.
#23
Oops! I was thinking you were running a custom OS. You still have ethanol tables though. So you would be copy/paste B3605 to B3648, zero out B3660 and B5947, and copy/paste the 0% column of B3642 to the 10,20,50 and 80% columns. You could do the same for the other E80-related tables(use the EFILive navigator to search "E80").
#25
Loaded the above tune and it ran like pure *** for a minute. The AFR started in the low 10s. Idled for **** and ran for ****. After a few hundred feet it seemed to be ok. It ran good and the afr was in the 14s at cruise and idle and low 11's if I got on it some. I attached the log. Tell me what you think.
There may be a few spots where the mph and rpms seem to go up really quick. It just rained and I turned the traction control off for some fun cornering
#27
FP holds with the key off. I do have 42# SVO injectors. It has always run a little rich at startup but not with the AFR in the 9's/10's. Usually in the mid 12's until warmed up (less than a minute) then it settles into the mid to high 14's.
I have not turned off the codes you listed. Not sure what that would do.
#28
Disabling B4206 would take the O2s out of the equation until warmed up to rule out an issue there.
