P0174/171 Mystery...need help.
Ok, sooo...
I've been battling P0171 and P0174 codes for the last...however many months. I haven't really noticed a change in driveability since I started getting the codes, but they are annoying me and I'd like to fix the problem and possibly gain some benefit to fuel economy or maybe even a little more oomph.
The issue started last year when I had my friend decat the truck at his shop. I had a couple of spacers installed with the rear 02s that keep the sensors from letting the engine know there's no converter. I'm not getting the no cat codes. Got code right after though (174 or 171 possibly). The light would go on and off every 1-5 days or so.
Recently, I took the truck in and had a smoke test done and no vacuum leaks were found. Fuel pressure was ok too. One of the 02 sensors (passenger side rear) was stuck in lean or rich (i don't remember). I replaced that sensor and since then It's been just the 174 code.
I tried cleaning the maf (a number of times). I would clean it, and soon after the light would go off. However, It would come back on the next day...or some days later. Clean it, same thing.
I thought the problem could be oil from the k&n so I replaced that with a high quality dry filter, cleaned the maf...same thing. Goes off, comes back on later.
Got a remanned maf to see if maybe that was the problem. Cleared codes...codes came back (but interestingly my mpg seems to have gone up 1-2 mpg after changing the maf out). When the light does come on, it seems to come on when the truck is idling. There have been a few times (but not very often) that its been a little sticky going from standing to moving (a little engine rev but not much movement).
Here are the freeze data points for the last time it threw a code:
P0174
rpm 520
load: 17.6
air flow rate: 5.35 gr/sec
map sensor: 41 kpa
short term fuel trim: 1 0.0
long term fuel trim: 1 7.0
short term fuel trim: 2 5.4
long term fuel trim: 2 25
short term fuel trim: 3 50
long term fuel trim: 3 45.3
short term fuel trim: 4 20.3
long term fuel trim: 4 50.7
fuel system 1: closed
fuel system 2: closed
throttle position: 4.7
Any help? Thanks!
P0174
rpm 520
load: 17.6
map sensor: 41 kpa
Any help? Thanks!
A tune fixing the issue would be ideal, as I have been thinking about getting a Black Bear tune once this was resolved.
So with a custom tune I could just plug up the rear 02 spots (not having any sensors there)? And then with the tune they can eliminate those readings from the computers table...is that how it would work?
Angry Silverado
10-21-2015 07:07 PM
Wrecker 426
09-30-2015 09:39 PM
kalikid06
09-13-2015 05:48 PM
SWINGRRRR
09-03-2015 07:49 PM
