P0300- Multi Miss Fire..... Help!
Old 02-19-2010, 07:53 PM
  #21
something else
ChevyTruck's Avatar
I have BBP but I don't have EFI Live. The light went off today on it's own after I put a qt. of Lucas injector cleaner in so I tried to go threw inspection and it still failed the Evap sys-not ready and O2 sensor heater-not ready.
I tried the brake clean on the intake while running and nothing happened. So that's a good thing, I hope that this problem is done and over with.
Old 02-19-2010, 07:54 PM
  #22
something else
ChevyTruck's Avatar
Do you think my MAF could be dirty? Also I ran open headers for a few days, could that of F'ed my O2 sensors?
Old 02-19-2010, 10:03 PM
  #23
something else
ChevyTruck's Avatar
Originally Posted by hirdlej
How'd those new 90deg GM plug wires work with your headers?
Took this last night with my phone.
Old 02-21-2010, 05:46 PM
  #24
something else
ChevyTruck's Avatar
Well the light is back on after over 200 miles of being off. It was only ideling with the heat running and it popped on. I was going to go threw inspection tomorrow and now I can't. ***!
Old 02-21-2010, 05:59 PM
  #25
greenz71's Avatar
Mine has been doing this for about 10,000 miles. It will come and go, I don't have headers and replaced the wires and plugs with no change. I cannot tell that it ever really misses so I have just been driving the wheels off it, I am glad that I don't have to go through emission testing. I think mine is related to an old O2 sensor issue that I have replaced. I know I have offered no help but just some support but, I am following along to see if you figure it out so that I can try the same thing.
Old 02-21-2010, 06:04 PM
  #26
something else
ChevyTruck's Avatar
I hear you man, our inspection the plug to the OBD port and check it that way. I will be sure to post what my end problem is/was.
Old 02-21-2010, 07:16 PM
  #27
eallanboggs's Avatar
You can see cylinder specific misfire counts in Mode 6. P0300 means the ECM can't narrow down the specific cylinder pulses coming from the CKP or maybe they really are random. Look at Mode 6 to be sure. If you don't have an aftermarket camshaft(causes rough idle which is another way of saying the ECM "thinks" the engine is misfiring) you problem lies elsewhere. Why is your idle vacuum so low? Do you have excessive blowby? Are you running a catch can to check for blowby?
Old 02-21-2010, 07:28 PM
  #28
something else
ChevyTruck's Avatar
How do I check "Mode 6"? And what is Mode 6? I don't know if my vacuum is low or not. Not sure of excess blowby. And no catch can.
How can I check if I'm getting blowby?
Old 02-21-2010, 07:43 PM
  #29
hirdlej's Avatar
Think you may have perhaps a bad crank or cam position sensor perhaps? I never thought of those.......
Old 02-21-2010, 09:04 PM
  #30
something else
ChevyTruck's Avatar
Gosh I hope it's not one of them...
Quick Reply: P0300- Multi Miss Fire..... Help!
