P0327 Knock Sensor Low Voltage
Originally Posted by BlownChevy
If you pull the supercharge system, just make sure your intake gaskets are good, more than likely you will need to replaced them.
Just tested the resistance of both knock sensors, which I guess are supposed to be right around 100K ohms each. Rear was right on, front was only 55K, so I guess there's my problem. Should I go ahead and replace both of them when I pull the s/c? How long are intake manifold gaskets good for? I'm gonna be pulling the motor apart in a month or two anyway for the LQ9 and I don't want to replace them twice.
Will that hurt anything? Knock sensors will still operate normally?
Originally Posted by Formulized94
hell worst case, if you have acces to a quick tune. take it out of the code table.
lucas287
31
01-12-2021 06:18 AM
Pontiac Derek
09-19-2015 01:49 PM
creekrat
09-10-2015 12:59 AM
