p0446?
Old 11-10-2008 | 01:43 PM
JAVI05's Avatar
Default p0446?
i need a evap solenoid? where can i find one? i know the dealer but anywhere else? dealer wants 109... has anyone replaced this part? thanks.
Old 11-10-2008 | 04:47 PM
JAVI05's Avatar
ok no one has replaced this??? i have done a search and no one has finished the thread with an ok its fixed or nothing.. come on guys????
Old 12-04-2008 | 10:35 AM
JAVI05's Avatar
ttt... anyone?
Old 12-04-2008 | 01:57 PM
Fireman31's Avatar
Have you tried to clear the code? Try removing and re-tightening your gas cap, then clear the code. It shouldn't come back.....
Old 12-04-2008 | 02:59 PM
JAVI05's Avatar
cleared it twice.. came back in some days. cleaned the sensor put it back and it came back.. ????
chevrolet all the way's Avatar
if you take off your gas cap with the truck running itll do that. sometimes it'll do it anyways
EDIT oh nevermind ya snuck in on me
Old 12-04-2008 | 03:05 PM
JAVI05's Avatar
lol. i have read threads about this p0446. and not one thread was finished with i solved the problem.. i really dont wanna buy the part and for the light to come back on thats what all i have been reading..
Old 12-04-2008 | 05:48 PM
Fireman31's Avatar
I just checked the background on this DTC, there are many variables that can cause this DTC to set. Here are some diagnostic aids recommended by AllData.......
DIAGNOSTIC AIDS P0446
-When using the Evaporative Emission System Tester (EEST) to apply pressure, you can regulate the amount of pressure by activating the remote switch ON and OFF while observing pressure in the EVAP system using a scan tool. DO NOT use more than 5 inches H2O. More than 5 inches H2O applied to the EVAP system can cause the canister vent solenoid valve to temporarily remain in the closed position, which could lead to misdiagnosis in this procedure.
-An intermittent condition could be caused by a damaged EVAP vent housing, a temporary blockage at the EVAP canister vent solenoid valve inlet, or a pinched vent hose. A blockage in the vent system will also cause a poor fuel fill problem.
-An EVAP canister, vent hose, or vent solenoid valve that has restricted flow may cause this DTC to set. Using a purge solenoid valve command with a scan tool will allow vacuum to be applied to the system instead of pressure. With the EVAP canister vent solenoid valve open and the EVAP canister purge solenoid valve commanded to 100 percent , vacuum should not increase to more than 9 inches H2O.
Old 12-05-2008 | 11:33 AM
JAVI05's Avatar
well my bro in law did that test with his scan tool and the tool said replace sensor.. so i guess thats where i am at now..????
Old 12-05-2008 | 09:52 PM
14psisupra's Avatar
i just had mine replaced today.charged me $140 for the part which they got from the dealer so 109 sounds good..are you on motohouston btw
