p0446?
#33
i been having the same prob ever since dealer put a new tranny in,got the truck back and it ran better than new then a few days later check engine light and it runs doggy off the line again,run a scan with my preditor and it gives me p0133 bank 1 sen.1 slow response and p0446 so i put in a new 02 still got the code then go fill up and the cap made the loud vacum when i loosened it,kept kicking the the gas pump off,was my 02 sen. ok and the evap code triggered it,is this coverd under warranty i got like 2 months left?
#34
If there is to much vacum in the tank it will cause performance issues. Believe me, I have done this on my own truck. I comanded the evap system to pull excessive vacum in the tank while on a test drive. It started to sputer and nearly died before the test shut down.
As far as the 02 sensor they either work properly or they don't. With out seeing what the rest of the system is doing and knowing some other variables its hard to say for sure. could be as simple as a loose wire at the conector or it could be more complectied such as a fuel delivery issues on that side of the motor.
I would say it is more of a coinsadence that this happened since they only did the transmission.
If you still have a factory warranty on the vehical it should be covered. if its a warranty on the trans then no.
Relentless07Silv
04-11-2015 11:55 PM
offroadrider12
03-28-2013 06:44 AM
