P1174 Fuel Trim Cylinder Balance Bank1
I have a P1174 Code That I have been dealing with since Cam Swap! Has anyone else encountered this problem if so what was the fix?
#03-06-04-030F: Various Driveability Symptoms Due to Clogged Fuel Injectors, MIL/SES DTCs P0171, P0172, P0174, P0300, P1174, P1175 (Clean Fuel Injectors and/or Perform Injector Test With AFIT - CH-47976) - (Dec 10, 2007)
Subject: Various Driveability Symptoms Due to Clogged Fuel Injectors, MIL/SES DTCs P0171, P0172, P0174, P0300, P1174, P1175 (Clean Fuel Injectors and/or Perform Injector Test With AFIT - CH-47976)
Models: 2000-2008 GM Passenger Cars and Light Duty Trucks (Including Saturn) 2003-2008 HUMMER H2
2006-2008 HUMMER H3 2005-2008 Saab 9-7X
with 2.0L, 2.2L, 2.4L, 2.8L, 3.1L, 3.4L, 3.5L, 3.8L, 3.9L, 4.2L, 4.3L, 4.8L, 5.3L, 6.0L, 6.2L or 8.1L Engine (VINs X, F, D, 4, 5, T, 8, J, E, H, L, 6, K, 1, 2, R, W, S, X, V, T, M, N, U, H, Y, 8, G -- RPOs LNF, L61, LN2, L43, LD9, LK5, LG8, LA1, LX5, LX9, LZ4, LZE, L52, L36, L67, L26, LZ9, LZ8, LGD, LL8, LU3, LR4, LM7, LH6, LQ9, LQ4, LS2, L76, L92, L18)
and MULTEC® 2 Fuel Injectors
This bulletin is being revised to update the model year to 2008. Please discard Corporate Bulletin Number 03-06-04-030E (Section 06 -- Engine/Propulsion System).
Condition
Some customers may comment on any of the following various driveability symptoms:
• Extended Crank Time
• Hard to Start
• MIL/SES Illuminated with DTCs • Hesitation
• Lack of Power
• Surge or Chuggle
• Rough Idle
• Light or Intermittent Misfire
Cause
Due to various factors, the fuel injectors may become restricted. Extensive testing has demonstrated that fuel related issues are the cause of clogged injectors. At this point, no specific fuel, fuel constituent, or engine condition has been identified as causing the restriction. The restriction causes the engine to operate at a lean air fuel ratio. This may either trigger the MIL to illuminate or the engine to develop various driveability symptoms.
Correction
Fuel injector restrictions, deposits can be cleaned on the vehicle using the following procedure. Under NO circumstances should this procedure be modified, changed or shortened. As a long term solution, and to prevent reoccurrence, customers should be encouraged to use Top Tier Detergent Gasoline . For further information on Top Tier detergent gasoline and fuel retailers, please refer to the following Corporate Bulletin Numbers:
• 04-06-04-047G (U.S. Only)
• 05-06-04-022D (Canada ONLY)
Notice: GM UPPER ENGINE AND FUEL INJECTOR CLEANER is the only injector cleaning agent approved for use with General Motors fuel system components. Other injector cleaners may cause damage to plastics, plated metals or bearings. General Motors has completed extensive laboratory testing of GM Upper Engine and Fuel Injector Cleaner, and can assure its compatibility with General Motors fuel system components, as long as the cleaning procedure is
Condition
• Hard to Start
• Lack of Power
• Surge or Chuggle
• Rough Idle
Cause
Correction
