P1518 rep mode
I have the new style xlink with no pink wires I have contacted nick it's has ls7 electronics he had me do some checks on the tb and all checked out fine with the even with 102 unplugged I get 10v for a couple of sec on the yellow and brown wires unplug the xlink I get 1.6v
Your readings on the Brown and Yellow wires are normal. They power the throttle actuator motor with 12V. The power is cycled on and off at a high frequency. The amount of on time on each wire determines the average voltage, motor direction, speed and position. On the Gen III trucks the throttle motor is powered up at key on, but this is cut after a few seconds if there is no input from the pedal or the engine is not running. These wires are not connected to the X-Link circuitry.
Do you mean TAC (Throttle Actuator Control Module) rather than TCM(Transmission Control Module)?
What year truck does your friend have that everything worked on?
Have you gone through the troubleshooting document?
Does this only happen at key-on?
That's not very clear. What year LS7? 2008 and earlier used the LS2 car TB (silver blade). 2009+ is the same as LS3/LS9 TB(gold blade). Not that it should matter in your case.
P1518 Diagnostic
P1518 Diagnostic
Yeah sorry the TAC. I only tried the nick williams he has a 03 (he bought evilgmc truck). He just installed a nw 102 and everything is a ok. I also pluged mine up to his truck no code. I haven't tried the my xlink. But he has the xlink that u have to cut the pink wires. I have went thru the tech doc and it said anything over 5.23v it will throw this 1518 and I gettin 10v also said that it should be a 0v to 5v from closed to open throttle. On those wires ???? Am I just confused ????
5.23V does not set P1518... a minimum system voltage of 5.23V is required for the P1518 test to run
Does this only occur at key-on?
It will start as long as I don't turn the key off and on again or I can start it with the code and clear it while it is running then again it fine till I turn the key off and on again
yes everytime but if i unplug the xlink and hook up a stock 78mm no code or even if i plug up 87mm with the x link its fine. so it sounds like the 102 is bad but i put the 102 on 3 other trucks and both were fine no code
i know i kept getting a p1518 code after doing a engine rebuild and it was a black ground wire at the back of the motor on the transmission bell housing that wasnt connected.. check and make sure its connected and has a good ground.. you can check it by jumper wiring it to the negative battery cable and it shouldnt do it anymore
