Passlock issue
Old 09-01-2008 | 01:46 PM
aaronmc's Avatar
Default Passlock issue
I think I'm having a passlock issue. I was installing my Sirius radio the other day and then after my truck wouldn't start. I checked everything I can think of spark, gas, fuses, everything looks good. I tried doing the security relearn procedure but that didn't help either. So my question is is there a way I can disable or check passlock in EFI somewhere? Any help would be great.
Old 09-01-2008 | 01:47 PM
7845's Avatar
Banned
i know in HP tuners you can ditch the passlock. but yes you can remove it to help aid in what your doing just not sure if EFI has it
Old 09-01-2008 | 02:31 PM
aaronmc's Avatar
I plugged my EFI live and read the DTC's. One error come up C0309 - Motor A/B Circuit High anyone have any idea what this means?
Old 09-01-2008 | 07:42 PM
viciousknid's Avatar
Where's the Beef?
Did you replace the stereo all together with one that has Sirius capability or did you just hook up a Sirius radio to the factory radio?
If you replaced it all together. Did you splice into the factory harness or did you use a plug n play adapter?
Old 09-01-2008 | 08:29 PM
icedenali's Avatar
do u have alram and remote starter?
cuz factory passlock should not give you a problem after u install sirus.
how did u install sirus? u have factory or after market head unit?
Old 09-01-2008 | 11:21 PM
aaronmc's Avatar
I just added the external Sirius radio.
I do not have a remote starter. I have an after market head unit with an external Sirius radio.
Old 09-02-2008 | 02:19 PM
icedenali's Avatar
ic~ are u using aftermarket harness to power up head unit? where did u tap+12v power from to get to sirus?
u might touch ignition line or something.
Old 09-02-2008 | 04:16 PM
What is the security light doing. That will tell you if it is passlock. A sure fire way is a start and die condition. Need a little more info to point you in a direction.
Idryfly5
09-02-2022 09:55 PM
murderedSS
27
10-12-2015 12:13 PM
TAPyvehc93
09-14-2015 02:22 PM
dselby25
09-11-2015 06:03 AM
Boyes50
09-08-2015 01:06 PM
