PCM Flash Woes... HELP!
formerly 1BADC10 (12/14/2011)
I bought a PCM for my truck, and planned on getting it tuned professionally (one day). I connected the PCM as required, then plugged up HP Tuners so I can read what's on it. Go to read it, and I receive the license "commit" prompt, but there's one problem... I only used 4 of 8 credits when I purchased HPT, and should have 4 available credits (for VIN-specific setup). See image file below, and note that there's no option for VIN-specific licenses. According to Chris@HPTuners, the problem seems to be that the PCM has no serial # coded to it. How is this possible. Scroll back up and note what's behind the Serial # field. Is there a way to get this coded? Does the PCM need to be reflashed by GM or what? HELP!
LS1Tech Sponsor
The Key to get into a blanked out $4000-$8000 area is always $ffff You put that key into the efilive window and it will give you access to the pcm for reading and writing. You can also use efilive to change the key to a normal key and unlock it forever.
