people with tbss intakes come on in (87mm tb wiring)
Old 04-19-2011, 11:47 PM
beingblueeyes's Avatar
Default people with tbss intakes come on in (87mm tb wiring)
i installed my tbss intake today and it went on with out an problems, but when i went to re-wire the truck 8 pin tb plug to the 6 pin 87mm tb that's when i steeped into poop. here's how i wired it:
the 2 wires left out are
gry: 5 volt ref
blk: low ref
it will idle fine @ 600-700rpm and rev in park ( revd to 3000rpm and almost staled out when it came back down) with out setting any codes but 1.5 miles into 3 mile "test track" the check motor light came on and it went into reduced power mode after pulling the codes they are
P2101 - Throttle actuator control module range
P0120 - throttle/pedal position sensor switch A and switch B malfunction
P0220 - ^^^
P1516 - Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance
pertinent info:
the tune has not been touched after i installed manifold/tb
did not use x link used different tac module (12574221)
so im thinking when i re-wired it i wired the 2 tps signal wires backwards. any other ideas?
Old 04-20-2011, 11:31 AM
i tried swapping the tps sig wires and it still doesn't work so i can now confirm that a 02 tac mod swap is 100000% BS with a truck 87mm tb. at this stage in the game with my power goils in mind i think ill end up buying a LS1 to LS2 adapter, i just cant justify spending 2x what i spent on a intake manifold and 87mm tb for a extra 9mm of tb blade
Old 04-20-2011, 11:33 AM
OnyxSilveradoSS's Avatar
x-link and be done.
Old 04-20-2011, 12:07 PM
yea i just caved and paid for one
Old 04-20-2011, 12:13 PM
FormerVendor
KLUG'S SS's Avatar
It'll make your life alot easier and less stressful!
Old 04-20-2011, 12:29 PM
Baltimore Whore
Mangled03gmc's Avatar
Can you use the truck injectors with this?? I read some mods may need to be done.. I want to use the truck rails off my intake( return style) What exactly can be done.??
Old 04-20-2011, 12:58 PM
FormerVendor
KLUG'S SS's Avatar
Their are many ways you can approach it, yes you can use your same injectors and fuel rails, etc.... with the return style setup.
Their is a decent write up on it somewhere let me find the link and post it up for you instead of me using up two pages of a thread. Hahaha
Old 04-20-2011, 01:08 PM
Baltimore Whore
Yes if you could that would be great.. There area bunch of write ups, but to sift through all of them, if you know the particular one, would be nice.. This is a great CHEAP improvement over stock. I was going to go vic jr or por flow, but it is $$$$ dude to all the **** you have to change.. All the NA dyno's I have seen have been atleast 15hp over the stock one to the wheels.. I would imagine a bit more for a FI set up.. To the orig poster, sorry for the thread jack..
Old 04-20-2011, 01:20 PM
FormerVendor
KLUG'S SS's Avatar
Here ya go bud! See if this helps, I think it's a pretty fair write up.
http://www.silveradoss.com/forums/to...e-swap-how-to/
Old 04-20-2011, 01:35 PM
Baltimore Whore
Yes sir sure did.. Now I am to the point if to should I keep the stock rails or go aftermarket.. LOL I duno wth im doing .. Thanks you sir
Quick Reply: people with tbss intakes come on in (87mm tb wiring)
