Please HELP!!! Baffled, stock motor problems
Moderately Differentiated
Originally Posted by 03RCSB
One more bit of info, the misfire problem only happens under load, if I drive around town and stay inder 3000rpm, I dont get any misfire codes, but once I head uphill or put some pressure on the engine, the code gets thrown I have not seen the po101 code again but the misfire happens alot.
Originally Posted by dewmanshu
hit your intake with a hammer ?
Nah I havent done anything to the truck. It has a catback on it, thats it for performance mods and the catback has been on for over 10,000 miles so. All the happened was about a day or so after I filled up I was getting onto a highway on an inclinded onramp and bam, engine loses some power and check engine light flashes, since then its just gotten worse.
They are probably real close to being plugged. One way to check would be to measure the pressure before and after the cat. If it is much higher before, it's probably plugged.
Since you are so close to being stock, I'd take it to the dealer. There is a federal 80,000 mile warranty on cats.
OK guys I got the truck checked this mornin, needed plug wires and an ignition coil, the shop wanted 670 to do the job, needless to say I took the truck back, paid them 100 for the dioagnostic test and then bought all the parts for $130.
The question is, the sheet says coil pack #1. Looking at the front of the motor, which one is that? also, what are the torque specs on the plugs?
Thanks for the help
Thanks for the help
Fock! replaced all the **** the shop said they were gonna and nothin, stil runs the same, they said there is nothin wrong with the cats, im headin to a friends shop so we can smoke test the intake and then seafoam the motor, Im def gettin tired of this crap
