Please HELP!!! Baffled, stock motor problems
Old 07-25-2007, 09:16 AM
Moderately Differentiated
dewmanshu's Avatar
Originally Posted by 03RCSB
One more bit of info, the misfire problem only happens under load, if I drive around town and stay inder 3000rpm, I dont get any misfire codes, but once I head uphill or put some pressure on the engine, the code gets thrown I have not seen the po101 code again but the misfire happens alot.
sure, this all makes sense, the maf takes over after 4K rpm. It plays a large part of calculations up to that rpm, so the more load the worse your fueling and misfire. Have you done anything recently, mods, changed air filter, hit your intake with a hammer ?
Old 07-25-2007, 09:52 AM
03RCSB's Avatar
Nah I havent done anything to the truck. It has a catback on it, thats it for performance mods and the catback has been on for over 10,000 miles so. All the happened was about a day or so after I filled up I was getting onto a highway on an inclinded onramp and bam, engine loses some power and check engine light flashes, since then its just gotten worse.
Old 07-25-2007, 09:57 AM
Hello Dave
dc_justin's Avatar
Originally Posted by Holty
Just throwing this out there but could possibly be a clogged cat although not likely at that milaeage and would not also cause a maf code.
Good call, that could cause both the code and misfire as well...
Old 07-25-2007, 10:04 AM
tdrumm's Avatar
Check your cats. I had a 2001 Grand Prix that did the same thing with the misfire codes above 4000 rpm. Replaced the cat and everything was fine again.
Old 07-25-2007, 10:13 AM
03RCSB's Avatar
Oh damn, never even thought of that. any way for me to tell? If I brought it to a place would they be able to tell by emissions that the cats are bad?
Old 07-25-2007, 01:29 PM
tdrumm's Avatar
They are probably real close to being plugged. One way to check would be to measure the pressure before and after the cat. If it is much higher before, it's probably plugged.
Since you are so close to being stock, I'd take it to the dealer. There is a federal 80,000 mile warranty on cats.
Old 07-26-2007, 08:37 AM
03RCSB's Avatar
Talked to an exhaust shop and im gonna bring it in saturday morning so they can take a look at it, ill let you guys know.
Random pic of the truck.......
Old 07-28-2007, 11:49 AM
03RCSB's Avatar
OK guys I got the truck checked this mornin, needed plug wires and an ignition coil, the shop wanted 670 to do the job, needless to say I took the truck back, paid them 100 for the dioagnostic test and then bought all the parts for $130.
The question is, the sheet says coil pack #1. Looking at the front of the motor, which one is that? also, what are the torque specs on the plugs?
Thanks for the help
Old 07-28-2007, 02:03 PM
03RCSB's Avatar
Fock! replaced all the **** the shop said they were gonna and nothin, stil runs the same, they said there is nothin wrong with the cats, im headin to a friends shop so we can smoke test the intake and then seafoam the motor, Im def gettin tired of this crap
Old 07-31-2007, 12:55 AM
Destroyer of Transmissions
1SlowHoe's Avatar
Checked the intake gaskets/TB gasket?
Also check the injector connections. Make sure the studs on the injector are making good contact with the actual injector wiring harness.
BTW, coil #1 is the drivers side, closes to the radiator.
Quick Reply: Please HELP!!! Baffled, stock motor problems
