Plot Filtering the VE
#22
LS1TECH Sponsor
dfco won't show a different commanded...a different actual, yes, but not a different commanded...your commanded will still be 14.63 to 1 or whatever according to the computer.
#23
How do I change this text
#24
Originally Posted by desTRUCKtive
Dumb question but if you do AFR> 14.6. This means that it will only record data that is greater than this value. Therefore due to tuning files you might have cells that actually run richer even without going into PE mode. But you will not catch this on your scanning because of the filter. Am I right.
Originally Posted by dewmanshu
ahhh, for some reason I never thought of "commanded". Makes tons of sense to filter out anything commanded outside the stoich. I was thinking actual. GREAT filter!
#26
hell no, I wish when I ordered it I would have. with these new additions to the new hptuners and credits I am all confused on what is what. I eventually want to get 1bar that way i can RTT and hook up my wideband to hptuners.
I am trying to hook it up with the AC. I will see if it works.
#27
Originally Posted by Wilde Racing
I like the idea of using both filters, in case you have DFCO enabled or overrun the engine...
I am going to try this but I am first want to see if I am understanding this right. The way that I understand this is that it is going to filter anything out in between 14.6 and 14.8 COMMANDED. Dont you want to filter anything COMMANDED outside 14.6 and 14.8.
I think I might be getting confused on the greater or less than signs.
#28
LS1TECH Sponsor
example
if you enter RPM>4000 its telling the scanner to ONLY USE the info when your over 4000 rpms so if you say RPM>4000 & RPM<5000 it will only take info from 4000-4999 and show you it.
#29
example
lukn4trbl355
10-21-2015 11:19 PM
