Ported TB, startup surge. Help!!
I just installed a ported throttle body. I get a bad idle surge when i start it up then it settles back down after a few seconds. How do i make this go away?
there is tables that can be adjusted for startup airflow and decay rates. if you are tuning yourself spend sometime with these tables or if you have someone tuning discuss the issue - make note of approximate air temp, engine coolant temp and how long the surge lasts
gmcyukon
10-04-2015 12:03 AM
KINGCYCLES
10-02-2015 11:21 AM
lxcoupe
09-25-2015 01:36 PM
