Which power inverter do you use.
That's alittle much for what I'm wanting. Mainly using it to power my lap top while I log/tune. I had one of the 100w ones that plugs into the cig lighter. Noticed some smoke coming up from the dash. Found out that the wires to the cig lighter got red hot and melted the everything around them. Thank goodness it didn't start a fire.
4GA will work fine for that as long as you keep it under 25'. I have mine running on 6GA but I rarely tax it.
You need a 120A fastblow fuse or in my case I just used a 100A delayed breaker. The unit will pull a hefty amperage if you happen to plug in something that starts with higher requirements than the inverter will normally supply.
SlvrSierra4.8
10-01-2015 09:39 PM
Superman09
09-25-2015 05:55 AM
b4z
09-10-2015 06:58 PM
