power level tunes??
power level tunes??
i was thinking about something, i dont know if theres such a thing like that, i thought this would be the best place to post it in, it might be interesting for some of you. i thought maybe putting two pcms in a vehicle where both are connected but only one working at a time so you basically switch between them, you let PCM 1 be a good tune which saves fuel by putting less power or something and PCM 2 would be a performance tune.
Is there such a thing like that, is it possible to make somthing like that?
you will be stacking up to 6 completely different tunes in one PCM,
you are adding more chips (circuits) into the PCM and than adding separate tunes to each chip
2nd fastest 5.3 ECSB
I plan on just one extra switchable tune. One that will arm the n2o when active so that I can have my street tune and then the one for the gas...with the failsafe that the nitrous cannot accidentally be activated. Haven't sat down and figured all the specifics yet, just thoughts.
