predator programmers
Yeah when I used the predator on the Dyno what I did was tune off the stock bin and if I remember right I was able to advance 6* degrees of timing and the fuel was barely
Even touched as it was already at a 12.8 afr. I tried leaning it out and playing with the timing but 12.7-12.8 is where it wanted to be with 87oct.
I can sell you magnetic fuel line clamps that will boost you by another 20hp.
I did that and had better results dynoing the truck with the handheld.this is the graph 5.3 intake pipe, Gibson catback, cat delete, 200+ thousand on the odometer,Dynoed predator handheld
this was the difference.
LS1Tech Sponsor
Ok, let me clear some things up here
If this is an OLD U7198, with version 1.XX or 2.XX, it can be sent in for the $99 hardware upgrade to be made into a newer tool, and at that time, we could change it to a U7193 for the 05 model truck. The upgrade will add datalogging, and make the tool internet updateable.
Customtuning is available, and the tools themselves have a bunch of adjustability.
You can alter spark and fueling at WOT, adjust idle speed, rev and speed limits, tire size/gear ratio, adjust shift points and firmness at WOT and part throttle...they are VERY useful tools
With custom tuning, there is no limit to what can be tuned with a Predator. I have customers with 800 rwhp blown combos, 900 HP N2O combos, and 100+ rwhp TT combos, all flashed with a Predator. Not so limited
I know the GM world likes to think handhelds are no good, but look around the Ford and HEMI markets, there is no other option (I guess HPt has some newer Ford stuff). Handhelds and custom tuning with those handhelds is the way of the world. Heck, if you have a HEMI, and you dont have one of our Predators/Intunes/Trinity tuners, you are the slow guy, period...
Lemme know if anyone has any questions.
LS1Tech Sponsor
The 4.8 is no monster, gains are about 17 rwhp peak on premium fuel. That could be tough to feel in a big truck, but i would be willing to bet there are gains should you measure it on a dyno or back to back at the track.
Tahnks
