quick question...
Old 10-27-2008 | 09:40 PM
silveradokidd_4518's Avatar
Default quick question...
i have an extra computer i want to sell to a friend. the extra computer i have is for an 02 and his truck is an 03. will the computer work i have work on his?
Old 10-28-2008 | 08:35 PM
dc_justin's Avatar
Hello Dave
It will not work for his 03.
Old 10-28-2008 | 11:10 PM
hog's Avatar
hog
Could his 03 PCM be used in the 02 truck with a Force Full reflash of the calibration file and the O/S?
peace
Hog
Old 10-28-2008 | 11:11 PM
BlackGMC's Avatar
Resident Retard
i don't think so cause the 03 pcm is a 1mb os and the 02 is a 512kb(or something like that) pcm... I may be wrong and i usually am....
Old 10-28-2008 | 11:13 PM
00ChevyScott's Avatar
Wearin' da big hat
sounds like somebodys been practicing for marriage
Old 10-29-2008 | 09:36 AM
dc_justin's Avatar
Hello Dave
peace
Hog
BlackGMC said it right. In addition to being a different size, the 03 has a green connector, 02 a red connector. Those connectors are keyed differently than each other which would make it impossible to connect.
Old 10-31-2008 | 07:41 PM
hog's Avatar
hog
OK but 512kb is LESS than 1024kb. I would think that 2002 512kb file would fit in a 1024kb PCM. I realize DBW 1024 cal. file couldnt be used in a non-DBW 512kb PCM.
I do have some new info. A 411 PCM can be used in place of the 243 PCM in a 2004 truck. I know this because its now up and running. We are using a 497kb 2002 L31 Express Van cal.file.
So we are using a 411PCM(512kb MAX) with a 2002 497kb Express/Savanna cal file in a 2004 truck that has an L31 engine that was originally controlled by a 1997 blackbox 192kb PCM. We even used the stock 2004 truck PCM connectors.
PCm's (1024kb or 1.024mb)with service codes
12576106
12586243
12586242
12583560
12583561
12589463
are interchangeable with each other O/S swaps.
The 411 PCM is a 512kb PCM, we directly swapped it in place along with its O/S in place of a 12586243 1024 kb PCM.
just to be clear, the 99-02 and the 03-07 PCM's BOTH have the Blue connector whil ethe 99-02 have a Red connector, while the 03-07 have the green connector.
99-02 512kb BLUE and RED
03-07 1024kb BLUE GREEN
So are we really sure about those connectors really being "keyed"?
Also how come an offboard tuning harness will fit all the 99-08 LSX PCM's, there no break for 99-02 and 03-08,?(the 97-98 LS1 PCM's being the red headed stepchild or course lol)
peace
Hog
Old 11-01-2008 | 12:02 AM
Wheatley's Avatar
Truck Sponsor
Yes the red is keyed different than the green for a fact
Best thing to do is just get the correct pcm,they are not expensive
Old 11-01-2008 | 12:06 AM
dc_justin's Avatar
Hello Dave
What Charlie said. The reason bench harnesses work is that the serial data pins are on the blue harness only. Same harness works with quite a few other PCMs as well...
Old 11-01-2008 | 03:55 PM
hog's Avatar
hog
Gm list on the 1MB PCms is $464-$514, obviously guys in the know wont buy them from GM. The 411 PCM lists for $277.98.
I am trying to illustrate that there is some flexibility within the 1mb PCM's, and obviously between at least the 243 1mb PCM and the 411 512kb PCM(pinout wise), as a 1mb 243 was pulled out and a 512kb 411 PCM was slipped in.
The internal differences within the 1mb PCM's are due to sourcing and whether the PCM uses Intel brand or AMD brand flash memory.
I am not trying to argue, I just think its imporatant info for those guys who are doing engine swaps and the like, who MAY do a search on this info.
I bid you BOTH a good day.
peace
Hog
andrewlong
11-09-2016 09:38 AM
Wrecker 426
10-07-2015 12:11 PM
andrewlong
09-08-2015 10:25 PM
2004gibbstruck
09-07-2015 06:05 PM
Quick Reply: quick question...
