Rafig Pids
Where's the Beef?
Rafig Pids
I'm still working on getting my friends 4.8 tuned. It has the cruise control effect when you let off the brake. It just takes off.
This is typically cured by tuning the Desired Airlow in Gear with the RAFIG process. However I can not get the idle trims to activate. They stay X'd even after logging has started.
This would be any of the IAT-Long term/Short Term correction pids.
Anyone know why I can not get them to read?
Vehicle is a '99 Silverado 4.8 4l60 214/220 110lsa. Idle AFR is about 15:1 and timing at idle is 20-23
I've increased and lowered B4307 in large and small increments and see minimal response.
Where's the Beef?
I'm going to go through the VE tomorrow and make sure it's good since I haven't spent a whole lot of time on it with the wideband. But for the Desired airflow do you still add the readings to the table when using the Maf G/S like you do the stit/ltit's?
Where's the Beef?
I'm testing your MAF theory out on my truck so that When I get to his I know what to do. I turned my MAF back on and was only getting a reading of 1.58g/s. Does this mean My MAF is bad or could there be another issue? I'm pretty sure the wires are hooked up but I'll double check.
Resident Retard
BlackGMC
08-14-2008 09:54 PM
kbracing96
04-20-2007 10:37 PM
