raising idle after stall??
1 Post
got the transmission buttoned up after the second breakage. It happened last time as well, but i didn't have any time to look into it. Is it typical to need to raise the idle after a stall? After the engine has warmed up and i come to a stop, sometimes the idle will drop low and the engine dies.. Especially if I turn the wheel really quick when the truck is idling in gear. I'm tired of having to hold the brake pedal and the gas at a stoplight so it doesn't get a chance to die.
Again, no cam. practically stock tune, stock idle rpm, etc etc. Does the idle need to be raised or should i be looking elsewhere? I cleaned the throttle body bore and blade. Air filter is NASTY dirty but i don't think that would cause it.
my truck does the same thing since I put my Circle D in, going thru a drive thru is simply embarasing and requires some skill.
How is it when you back up?
I am sure Justin will get it all fixed up since I recieved my black bear auto cal
How do I change this text
That only has to do with the throttle blade during transitional state. What he is describing is solid state idle. I have had very good luck with logging and adjusting the base idle air flow table. Keep in mind what has changed, the smaller converter will always make an engine harder to stay at a steady idle.
1 Post
Gingervitis Addict
Even after a stop it still has to delay/decay for a short period.
murderedSS
27
10-12-2015 11:13 AM
