Rear 02s
Rear 02s
Ok i got a quick question for you guys..
Im fixin to order a Eaton LSD and 4.10s..
but while im recovering from that and saving up for the LT headers and ORY pipe, could i gut my cats and turn my rear O2's off with EFI Live and pick up any power with the stock manifolds??? I have replaced my stock muffler with a 6"Rd magna flow.
If so where do i go in EFI Live to turn them off at?
and is there anything else i need to change?
Thanks Guys!!!
Thanks Guys!!!
im sorry i think that i missread your post... you will gain some power by gutting the cats..... makes it flow better but in all honesty your stockers flow good not sure if you will notice the power that you will gain
ok.. i wont worry bout it then.. ill wait for the LTs and ORY. Thanks LesPaul!!
But ill still need to turn off the Rear O2s when i get the LTs...
How do i do that with EFI Live???
High on diesel fumes
A couple things to change:
Engine Calibration -> Cat Converter -> Catalytic Converter Protection Enable: {Disable}
Engine Diagnostics -> Engine DTC Processing Enablers -> P0137 "O2S Circuit Low Voltage Bank 1 Sensor 2": {X: Not Reported}
Engine Diagnostics -> Engine DTC Processing Enablers -> P0138 "O2S Circuit High Voltage Bank 1 Sensor 2": {X: Not Reported}
Engine Diagnostics -> Engine DTC Processing Enablers -> P0140 "Circuit Insufficiency Activity Bank 1 Sensor 2": {X: Not Reported}
Engine Diagnostics -> Engine DTC Processing Enablers -> P0141 "O2S Heater Performance Bank 1 Sensor 2": {X: Not Reported}
Engine Diagnostics -> Engine DTC Processing Enablers -> P0157 "O2S Circuit Low Voltage Bank 2 Sensor 2": {X: Not Reported}
Engine Diagnostics -> Engine DTC Processing Enablers -> P0158 "O2S Circuit High Voltage Bank 2 Sensor 2": {X: Not Reported}
Engine Diagnostics -> Engine DTC Processing Enablers -> P0160 "Circuit Insufficiency Activity Bank 2 Sensor 2": {X: Not Reported}
Engine Diagnostics -> Engine DTC Processing Enablers -> P0161 "O2S Heater Performance Bank 2 Sensor 2": {X: Not Reported}
Engine Diagnostics -> Engine DTC Mil Enablers -> P0157 "O2S Circuit Low Voltage Bank 1 Sensor 2": {No Mil}
Engine Diagnostics -> Engine DTC Mil Enablers -> P0158 "O2S Circuit High Voltage Bank 1 Sensor 2": {No Mil}
Engine Diagnostics -> Engine DTC Mil Enablers -> P0160 "Circuit Insufficiency Activity Bank 1 Sensor 2": {No Mil}
Engine Diagnostics -> Engine DTC Mil Enablers -> P0161 "O2S Heater Performance Bank 1 Sensor 2": {No Mil}
Engine Diagnostics -> Engine DTC Mil Enablers -> P0157 "O2S Circuit Low Voltage Bank 2 Sensor 2": {No Mil}
Engine Diagnostics -> Engine DTC Mil Enablers -> P0158 "O2S Circuit High Voltage Bank 2 Sensor 2": {No Mil}
Engine Diagnostics -> Engine DTC Mil Enablers -> P0160 "Circuit Insufficiency Activity Bank 2 Sensor 2": {No Mil}
Engine Diagnostics -> Engine DTC Mil Enablers -> P0161 "O2S Heater Performance Bank 2 Sensor 2": {No Mil}
Thanks Thunder, DLH2006, and LesPaul..... i got that saved now...
So basically all that does is.... it wont read the rear 02s and then disable the MILs so the SES light wont come on??
Corvette454l88
09-01-2016 01:24 AM
